M
meego
Why do theese motors require a start up circuit?
What is the function of the phase monitor?
Discuss 3 phase motors in the Electricians' Talk | All Countries area at ElectriciansForums.net
Once a supply is connected to a three phase induction motor a rotating magnetic field will be set up in the stator, this will link and cut the rotor bars which in turn will induce rotor currents and create a rotor field which will interact with the stator field and produce rotation. Of course this means that the three phase induction motor is entirely capable of self starting.The need for a starter therefore is not, conversely enough, to provide starting but to reduce heavy starting currents and provide overload and no-voltage protection.
There are a number of different types of starter including The Direct On-line Starter, The Star-Delta Starter Auto-Transformer and Rotor resistance.
Phase Monitor Relays protect against unbalanced voltages or single phasing regardless of any regenerative voltages.
Reply to 3 phase motors in the Electricians' Talk | All Countries area at ElectriciansForums.net
