Discuss TN-S supply 4.2ohms, this is the solution from the DNO! in the UK Electrical Forum area at ElectriciansForums.net
Yes thats right,couldnt believe it myself when I first heard it, and theres me going made at mrs for putting a lead through letterbox to mow lawn(before I did outdoor socket) as I didn,t think it safe.
well if you did the right thing by Mrs d...then whats the DNOs angle with this carry on.....supply cables through letterboxes....tut tut....
just a point if you wanted to be picky if you triped there rcd does that meen u have to call them to reset it as you cannot touch there equipment?
ive had similair situation high ze reading etc but to be fair to them they sorted the problem within days, i doubt the landlord is that bothered too as you will be talking in foreign language to him, it may pay you to issue a danger cert to the landlord just to cover your self he may persue the matter to a satisfactory conclusion. either way your --- is covered.
Reply to TN-S supply 4.2ohms, this is the solution from the DNO! in the UK Electrical Forum area at ElectriciansForums.net
