- Reaction score
- 771
It seems that there is a lack of understanding of the difference between statute & civil law.
Also, why is it if someone suggests not complying with the latest version of BS7671 when they are doing an install or modification then it sees that they are wrong and must comply with this standard.
However, when it comes to electrical areas that are covered by other standards & statute law, people seem blasé in their interpretation and have no care for compliance with the statutory requirements?
I'll bet that most people who are working on electrical systems outside the scope of BS7671 do not hold copies of the standards & statutes to which they must be working?
In case you are not aware, in the event of a case, if you are not in possession of the relevant standard and statute to which you must be working then you will be deemed as non-compliant by the court.
Oh and the expert witness will make mashed potato out of you.
If you modify a machine control then you must upgrade it to current standards or, be prepared to face the music if it goes wrong, and, it may be a totally un-related incident.
If you are designing & implementing control system modifications then for your sake I hope you can prove competence & have suitable insurances in place, because due to FFI, you could easily be hit with a very large bill.
I can't understand the vehemence with which BS7671 is defended on this forum, and the total disregard for other more onerous requirements for electrical works, it is beyond my comprehension.
