Currently reading:
*help please*2 way switching landing lighting
Discuss *help please*2 way switching landing lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
like I said I have done all that and identified everything then all I seem to get is either 2 way switching working fine and all downstairs lights and no power upstairs or no 2 way switching and everything else working
So post a diagram of the cables and connections you have identified
hope he's not going to say saneon driver and a voltstick
only way to do it is go to basics. start at the beginning, ID all cables, draw out a diagram if it helps.
Disconnect everything on the circuit, meter out wire by wire, ferrule every wire, make a drawing and connect as required to get the circuit working correctly, then post back on here to let us know what your mate had done to cock it all up.................
- - - Updated - - -
I was a bit late
we all get blonde moments, though, murdoch. several times i've been head scratching, gone out for a smoke and the penny drops.
But loads of the twxts on here don't exactly install confidence, nor like answering direct sensible questions posed by people TRYING to help.
Reply to *help please*2 way switching landing lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
