Currently reading:
How to run electric to my shed.
Discuss How to run electric to my shed. in the UK Electrical Forum area at ElectriciansForums.net
L
Lee Duncan
Evening folks,
Im Lee and I am looking for some advice on how to run electric to my shed. I have been searching the net for help but there's been so many different answers its starting to confuse me. I have never tried this before but I am an experienced diy'er and will give anything ago once.
I will be using my shed to fix and build motorbikes so I will be using power tools. I'm wanting to have 3 strip lights and maybe 4 or 5 double sockets.
My shed is approximately 10ft from the back of the house, it would probably be 24ft from the main fuse box. ( main fuse box is located in the cupboard at the front door)
I know I'm going to have to dig a trench to run the wire from the main fuse box to the shed but not sure how deep plus the wire will be run underneath a path, will that be safe?
Can someone please tell me how to do this and what wire, fuse boxes etc etc i will need?
Any information would be a big help as I would like to give this a go myself instead of getting a sparky in.
You mean prostitute himself.....disgusting! :)
it would appear as though this thread has run its course, and lee has had all the sensible advice he is likely to get.
surely it can now be closed?
ps- lee- I understand why you asked, and understand why you want to do the job yourself, but as I'm sure you're now aware, it ain't as straight forward as you first envisaged. with that in mind, just get a sparky to do it for you, and save some cash by digging the trench for them. when you were a joiner, did you not meet any sparkies and become mates? you could always do a job for a job if that's possible...
Like you, I've been through that with my mum, but because my parents lived a prudent life, it cost her £195.00 per day for the last 5 months of her life.
Yes, mine led a prudent life too ..... same living room carpet for 40 something years same with the kitchen. No central heating - just an open fire that burned smokeless fuel. Never spent a penny on the house, never had a holiday abroad or even left the country. Dad worked for the same firm for over 30 years all hours that God sent - even Christmas day more than once and paid his dues.
Meanwhile, another bloke working in the same job did the bare minimum, had holidays abroad every five minutes and saved nothing. Guess who got all the help when it was needed.
The last time I asked for something for Mum, the two Social Workers arrived and all they were interested in was getting yet another Financial Assessment completed, then they wondered why I threw them down the front steps ...........
Regardless of any of the good advise that's been given to this idiot, he will still go ahead with his planned installation, because he like many others that come here, always think they know better!!
Recently quoted for a shed, 22M 4mm swa run, under lawn and gravel path, RCD IP65 CU in shed, 2 sockets and one strip light, off house CU using an empty way.
Quote was just over £300 - chased up response as was told way too expensive not going ahead.
Must learn to say no to domestic......
I always cringe now when someone asks for a quote for outbuilding or pond supplies, and usually tell them over the phone that they're most likely looking at a few hundred pounds. That's when they say "but it's only for a few sockets and a light. I was expecting it to be under £50".
Saves me a wasted trip.
So then, if Part P exists in England and Wales, does this mean in Scotland it is a free for all and anyone can wire up anything? No building or notification regs?
There's plenty of regs! Having worked in both countries I can honestly say that the Scottish system is much clearer and easier to work to, also, the Electrical Trainee problem is much less as the scheme's do not have part P to use as a lever
So WHO is determining them as competent then??
I was under the impression that you needed a SJIB registration number to notify work to the LABC??
The NICEIC and SELECT are the schemes which operate up here but a lot of what is notifiable in England is not notifiable in Scotland. The standards which are required to have work passed by the LABC varies from area to area. Most of them like to see a photocopy of your SJIB card to go along with the test certs which you supply when an installation is completed. There are still people operating who are not qualified but there doesn't seem to be as much of a problem as you cannot just do a short course or a night course and then be registered as an electrician or domestic installer. To be graded as an electrician in Scotland you must have served a full apprenticeship or have a lot of years & experience along with cast iron references. The SJIB seem to be much stricter than the JIB.......that's I how I understand it anyway!
- - - Updated - - -
Maybe our jock brothers can answer that one.
I am no brother of yours! lol
This type of thread must pop up often and I dare say most will go ahead and do it anyway. Whilst I would not like to advise helping them connect to consumer unit etc can we not advise them of buried swa terminated into a joint box protected by a RCD plug and 13A fuse and the other wired into a double socket or 2 in the shed.lights and all on plugs not ideal but if done correctly its cheap and safe and must be better than bodged twin and earth in hosepipes etc. and no part P
This type of thread must pop up often and I dare say most will go ahead and do it anyway. Whilst I would not like to advise helping them connect to consumer unit etc can we not advise them of buried swa termanated into a joint box protected by a RCD plug and 13A fuse and the other wired into a double socket or 2 in the shed.lights and all on plugs not ideal but if done correctly its cheap and safe and must be better than bodged twin and earth in hosepipes etc. and no part P
The thing is, how would any Local Authority know if someone has wired up their shed without notifying or getting a qualified person to do the work? It scares me when DIYers appear on these sort of forums and think its as simple as wiring a plug!
been asleep have you?....
Read his other posts. My thinks we have a smart arse on our hands. This forum is supposed to be for professional sparks!
Reply to How to run electric to my shed. in the UK Electrical Forum area at ElectriciansForums.net
