Discuss Advice needed after electricity tripped in the Electrical Forum area at ElectriciansForums.net
Lois93
Can anyone help with an issue i have. My electricity tripped earier i think it was the extractor fan that blew. I have since turned it back on however now my oven will not come on. Neither will all the plug sockets upstairs and down. The only ones working are the ones in the kitchen above the worktops. Any advice much appreciated.
littlespark
Is there an rcd in the fuse board covering several circuits? Check all the little switches that should be up, are up.
Post a photo of the fuse board if you’re not sure
Could be a multitude of things and needs inspecting and testing by a competent electrician, preferably one who has a recognised 'Testing and Inspection' qualification.
As above, obviously check to see all switches are actually in the 'on' position. If they are not, try to turn them on. If they immediately trip again don't try to force them up and get someone in.
OP
L
Lois93
Its a really old fuse box. Here is some pictures of it now. Im not quite sure what a rcd is.
Thanks for the reply.
  • Advice needed after electricity tripped E11B2CD0-2A86-431D-B0EA-F2269066C357 - EletriciansForums.net
  • Advice needed after electricity tripped FD863627-A602-48CC-9F90-4F2D7F4EE326 - EletriciansForums.net
  • Advice needed after electricity tripped 445A4886-0CB1-48D6-B3E4-1D2168377E71 - EletriciansForums.net
pc1966
The RCD is the white box with the test button.
I suspect it was a line-earth fault and it took out both a fuse and tripped the RCD. Those are rewirable fuses so theoretically it is just a change of wire, but in practice it is a little harder to do properly and while you are at it you really should check the correct wire is used in all of fuses, as some folk put in any wire to hand which can be dangerous.
It would be worth getting @telectrix over to sort that and check the circuit just in case. For boards like that I would normally change the fuses to plug-in breakers, it is far short of a proper change/modernisation, but it can be cost-effective for cases like this when there is an RCD that (hopefully!) is working correctly.
Reply to Advice needed after electricity tripped in the Electrical Forum area at ElectriciansForums.net
Hi all - been an idiot / schoolboy error - drilled into a wire that drops down to a fused spur socket in the kitchen (for washing machine I think)...
Hi Our oven stopped working suddenly including the clock. It was on the fan oven setting at about 150 degrees. I checked the fuse board - it had...
I have found out that my electricity supply in my external garage is wrongly connected to my neighbours electricity unit in their house and their...
I have had no issues until this week. The lighting in my basement all has gone out. This includes my laundry room, basement game room, and the...
Looking for some advice please. I have lived in my property for almost 7 years now. Since living here every 6 months my heating element blows in...
New Posts (Please Reply)
