Hi new here so take it easy chaps !!
A client of mine wishes to supply their catering van from a new generator they are purchasing, I believe it is single phase 7.5kW Inverter style generator with a 32 amp socket outlet. My query is about the earthing to the van.
The van has a DB inside with a 30mA RCD main switch and an earthing conductor going to an earth electrode.
What will happen at the generator end is my question, I presume it will be a floating earth system.
If there is an external earthing nut on the generator, is it as simple as installing and earth electrode to the nut?
Or do I some how have to reference one of the line outputs to earth, if so how do you do that, surely I don't take the generator apart ?
Or will the earthing nut already be connected to one of the line conductors and its just a case of staking it down as I said earlier?
Any help would great, thanks.
