i=p/u
wonder can anyone help, i have a danfoss 2 channel timeclock which was switching itself on, i had a grasslin towerchron QE2 2 channel time clock in boot of car and swapped it over but it just runs heating and hot water even before anything comes up on display screen.... i thought would be straight swap but obv not
any help or questions i should be asking myself would be appreciated....
There will be a maximum of three switched outputs...HW on.HTG on and HW off,you cant go far wrong,just get your voltage tester out and see whats what.
Disconnect the two switched outputs from the clock and see if the valves close and everything shuts down,if so it must be the programmer or the way you have connected it.....or yes,you had a sticky valve all along.
i=p/u
Northern Ireland
United Kingdom
CH heating time clocks
i=p/u,
Leesparkykent,
