Currently reading:
Cheap EICR prices
Discuss Cheap EICR prices in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
£150 sounds more like it for an average sized house eicr.
pricing by the circuit is the best way, an eicr is just that.
if its just loose connections etc ill tighten as i go but anything more is noted with X amount to fix, preliminary cert issued or not completed fully depending on client.
why write it twice if they want you to fix it
£350 is steep even for Aberdeen.half a shift for a flat and a full shift for a house is probably more like it.
the problem with eicr's is that you don't know what's involved until you get there.
it could be sound without a grommet out of place .....you're in and out quickly.
at the other end of the spectrum diy donnies school of wiring.... Not so quick.
my rule of thumb is the more I find the longer it takes , the more I charge.
book a day, if it is going to take longer you tell them and let them how much etc.
your testing not fault finding so should do standard tests then code and if you are charging day rate only after rest is complete start to fix problems.
your bassically doing an mot on the house.
how many centers fix problems as they find them and pass it?
I got an email ages ago from one of the drive by testing companies saying they could do EICRs on my behalf and I could charge the client X amount and that they would only charge me, say, £80.00. I emailed them asking how many lims were put on these cheap reports, and why would I want such shoddy work to be presented under my business name. Got a reply quick sharp, must have really riled the bloke! Will try n find it, but it was ages ago and not 100% which email account I would have used.
Found the email I sent.
I sent this: Screenshot_20160105-003620.jpg
And received back this:
Hi Neil
Thank you for your email can I clear something up first the email says FROM £5.00 a circuits and also it says FROM 25 to 50.
This is depending on site and limitations applied by customers.
We work with many FM and Local Councils and £5 - £7 is the going rate across the UK most housing contract (edited company names) expect 3-5 house a day at £35 a house so our prices are not really that cheap and are aimed so companies like you can add there bit on top and still be competitive.
We make nearly 6M in profits and growing so our pricing structure is working just fine.
I also think that if you contact all big electrical testing companies and ask them what they can test in a day they will all be around 25-50 a day.
Of course we only test what is safely possible to do so in a day and don’t compromie standards.
I am very sorry that you feel like this but the industry is the way it is however if you have issues with us I welcome you to come and watch one of our testers on site.
By the way we are passed each year by NICEIC, NAPIT and the ECA as it clear DO know better than them.
Kind Regard
£35.00 per house!! And six million in profits means sweet FA, plenty of loaded cowboys out there!
EXAMPLE
Lets just take a 3 bed semi for example, old wylex 3036 box retrofitted with MCB's, only 6 circuits.
Sockets Up
Sockets Down
Lights Up
Lights Down
Water Heater
Cooker
1. First of all I walk around the house in every room with the customer and look for any obvious problems.
2. Agree anything that you are not going to test or take apart with the customer such as light switches embedded in the walls with plaster and light fittings that are likely to fall apart or awkward to remove.
3. Unplug everything and switch all SFCU and 20A Switches off and remove lamps, then switch on all lights
4. Check bonding to water, gas and oil etc
5. Go to board, do a Ze
6. IR each circuit in turn at 250vDC to check to see if anything connected still, then 500vDC
7. Do end to end on rings
8. Cross connect rings to do R1+R2, go round all sockets to take readings
9. Jump L - E for each radial and do R1+R2 for them.
10. Put it back together, switch on
11. Do Zs on sockets, and calculate Zs on radials where no socket available or easy to do.
12. Do a functional test of switches etc
13. Check metering equipment and tails etc
That's about it... I think?
When doing an EICR, Ill remove a few faceplates on sockets and see what its like, if its ok, ill leave the rest, if not, ill continue, either way, I make a note of the ones I have looked at.
The light switches, again, if they are embedded in the wall or is going to damage decoration, then I don't look at them and they get noted down. Light fittings that are going to be majorly problematic to remove etc I don't, this is more for 12v or double insulated etc where you cannot get an earth reading.
The loft space, again, ill say whats in the loft, if they say no power or light I ignore it, if they say a light etc, ill include it, but if its inaccessible due to rubbish in the way, it gets noted down.
Typically it takes me about 3 hours or so to do a 3 bed semi properly, I would say thats about right.
I don't think im doing anything wrong with how I do it, obviously I write everything down, all readings and figures etc etc and then type it all up nicely along with any findings.
For this I would charge £125 - £150
Would you believe it, I have just had an email drop in my inbox.... see below
************* is a specialist Anonymous subcontractor for testing and inspection. We can help you by providing a quality inspection service to your clients either at those times when your staff are busy on other projects, or as an addition to your current provision.
The inspection work is carried out under your brand, you can use Inspexx for ongoing projects or just for occasional assignments.
Features of our service include:
  • Experienced and Qualified Technicians – all staff are C&G qualified and CRB checked.
  • ECA registered member.
  • NICEIC registered member.
  • BSi 9001 Quality Assured.
  • Branded reporting – the inspections are carried out under your name.
  • Confidential – we do not contact your customers or share client information.
    Our services include EICR, PAT and Emergency Lighting testing.
  • EICR: £5.00 per circuit (minimum charge per site £150.00 up to 30 circuits)
  • PAT: £0.55 per test (minimum charge per site £75.00 up to 100 tests)
    The reports are sent directly to you. You can pick up any remedial requirements
Kind Regards
Kind Regards
Kevin McCallum
Badly presented website and 1000+ circuits for £5.50 each (presumably plus VAT so about £6.10 - I really pity the poor mugs doing this work!
And PAT testing for 100 items £75.00 - well at those prices they can keep it! My minimum is now £60.00 for 24 items and its difficult to make any money at that rate (£2.50 per item)!
Kind Regards
That's the one I emailed ages ago. Different fella, and can't recall the minimum £150.00 for, ahem, cough cough, 30 ccts!
EXAMPLE
Sockets Up
Sockets Down
Lights Up
Lights Down
Water Heater
Cooker
Yeah sounds fair enough, but some houses are so cluttered with sheet you can hardly move. And then there's the pet dog trying to chew through your wander lead! Bad/dodgy wiring can slow me down as my head tries to comprehend how it has actually been wired up. Always a FI for something like that.
It's very very tempting to employ one of these to test your own house to see what sort of monkey turns up!
Yep, I've been tempted myself mate. Or I might try them out on another property and doubled check a couple of the results myself to see if they tally up.
If they charge 150 for up to 30 ccts then surely they can do 6 ccts properly. Could knack the shuttering on a couple of sockets to see if they pick up on it!
EXAMPLE
Sockets Up
Sockets Down
Lights Up
Lights Down
Water Heater
Cooker
Sounds ok, apart from continuity should be done before insulation resistance. ;)
It's necessary in a RFC.
I know R1+R2's are not required. Although I always do them.
There's no point doing insulation if the circuit has no cpc for example. It's going to need repairing then re testing.
Its not a case of any tests not being required, its that for an eicr the order of testing doesn't need to be adhered to the same way it does for initial verification
Reply to Cheap EICR prices in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
