I Have had this issue in work, change one ballast another goes a few weeks later,
now I just get everything on that switch changed to led, so much easier.
I used to be of the "repair it "mindset. What tipped the balance for me was when a "Made in W Germany" ballast caught fire.
I know there's a lot out there that aren't nearly as old but these days there are so many reasons to go LED.
Or swap the whole thing for a 600 by 600 led ceiling tile. £20. Easy.
But I'm in the rip it all out for LED party.
We are supposed to be saving the environment, not throwing large amounts of working things in the bin!🙂
Reactions: GBDamo
Throwing things in the bin and replacing them with something that lasts almost indefinitely and uses half the energy while doing the same job is saving the environment.
You are probably right. I just have an image in my head of a mountain all those thousands of LED floodlights that fail after 6 months use, mixed in with that model of 2 part JCC downlights that lasted half that! But then I'm negative like that! Though this is usually the fault of the manufacturers, running the LEDs at the maximum rated current. If they just reduced the power to the LEDs by a watt or two the LEDs run cooler and will last substantially longer, with only a small reduction in light output.
I know a lot of things are better now than they were a few years back, but it is unlikely the LED lights will outlive a fluorescent fitting with a magnetic ballast. One place we work has a large number of 600x1200 lay in fittings, used 9 hours a day, 7 days a week. The date stamped on the ballasts is 1988. My grandmothers house had 3 working 4' fittings when I rewired it dated 1963.
I also find a lot of LED lighting plain and uninspiring. Some of the light fittings and building lighting designs from the 1930s and 40s were amazing I would love to go back in time to see them in person. I'd also love to see that enormous Ford neon sign at Dagenham while I'm doing some time traveling, installed mid 1930s IIRC. Neon is so cool and glowy.
Update....
It wasn't the ballast!
The 'non working' light fitting has 2 fluorescent tubes in it. The 'working' light fitting next to it has 1 fluorescent tube in it. Both lamps to look at are physically identical. So, i had put the working tube into the non working lamp fitting. It didn't work, so i assumed it could not just be a faulty tube.
However, (and this really high lights my lack of experience with regards commercial items) the tubes must have different wiring configurations inside them. I have just been back and tried some different tubes from a light fitting that actually takes 2 tubes.... and it works fine! 😞 Oops.
^^ was going to say some of them tubes looked quite black on the ends, normally a good indicator.
Reactions: Sapper
Is there a model number I should be looking for? Below are pictures of the one that I do want and the one that I don't want. Is it the PL-L and CLL marking that indicate the difference? Or some of the other markings?
There seems to be many PLL on line but no CLL. Is CLL now known as something different? I notice that '2Gll' is used, perhaps this means 2 gang and is the correct one?
For example this is a picture of the identification marking that I DO want:
As opposed to the one I don't want:
HappyHippyDad
Supporter
Gloucestershire
United Kingdom
Do I replace the ballast?
HappyHippyDad,
HappyHippyDad,
