Hi All,
I hope you are well. I am doing some earthwork in the front yard and realised that at this stage I could lay some electrical wires in advance.
Last time when I asked here about delivering electricity to my shed/garden office some people recommended 90mm or 35mm SWA which is ridiculous for the application not to say it is terribly expensive. The electrician said that 10mm armoured SWA is more than enough.
10mm armoured SWA in itself is so thick you cannot bend it unless you allow for a 2 feet wide bend. To run it though a wall and to connect it to the existing consumer unit is hard if impossible and ideally it has to be converted to unarmoured 10 mil. So how I supposed to wrestle with this 90mm or 35mm wire. I believe there are some jokers on this forum.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My plan is to lay a wire for:
1. front yard / gate lights
2. small motorised sliding gate
3. charging port
I understand for lights 1.5mm SWA armoured wire, gate motor - 2.5mm SWA armoured wire, a charging port 5mm or 10mm wire?
Please advise
Thanks in advance
3. charging port
Please advise
Thanks in advance
