- Reaction score
- 10,616
Have you taken parallel paths into account?
Of course I have, consider it and ruled it out
Discuss Existing Supplementary Bonding in the UK Electrical Forum area at ElectriciansForums.net
is that working in the shires with bilbo Baggins thenGonna give it up soon, go work down the garden center, moving green stuff about, and advising Mrs Miggins on what to put in her borders
what's the betting he will put them in quick and easy .What do ya think? Could always get the plumber to use push fit.
Then happy daysOf course I have, consider it and ruled it out
Then happy days
ring Gandaf ,lord of the ringsDunno, but sounds good, how do I apply?
Just replacing like for like luminaires.
If you can imagine, the rest of the refurb is fancy tiling, shower screens, furniture etc. Do I have to put that ec clamp on the bottom of their nice new chrome towel radiator?
Edit, oh and moving extract fan into loft space.
If you are moving the fan then surly this is an alteration. If so 132.16 applies and you'll need an RCD for the fan.
I got pulled up on an alteration on my last assessment, I moved 6mm gas bonding from wrong place to correct place, 2 minute job. He argued it was an alteration and as it was PME I now had to upgrade to 10mm.
I have perhaps the opposite situation, and I'd be pleased for any thoughts ... water bonding has recently been upgraded to 10mm (PME) and attached to a new pipe location and it's not at mains entry, but I see why they put it there. I'm working in the kitchen, cover off CU for a new circuit and behold there is the old water bonding cable curled up inside but not attached to earthbar. It's 6mm and goes upstairs to the bathroom where it's still attached to the bathroom copper pipes. I'm going to remove it (?) but I may need red wine to dull the pain.
Going back to 15th edition there......if it's metal bond it.So towel rad pipe at 0.04ohms, doesn't require local supplementary bonding?
Reply to Existing Supplementary Bonding in the UK Electrical Forum area at ElectriciansForums.net
