The problem is it's only my logic that says it's them. There is no proof.
I've changed the fuse to a plug in mcb for them, for my own peace of mind I don't want them struggling in the night They can just flick the switch instead.
Doesn't solve the problem just helps them get power back on.
So the Cowboys who installed the boiler didn't leave any paperwork, a MNWC as an example?
OP I think by now you should have got an electrician in to check the installation. It's possible an appliance is causing the fault, but you need to be sure. Adding a plug-in MCB, might make it easier to reset the faulty circuit, but you can't just keep resetting it every time. It's possible at some point the MCB might not operate correctly, which could be dangerous.
Call in an electrician. In the meantime, disconnect every unnecessary appliance.
The electrician from brother in laws work is coming but just taking a while for him to get round. Been 3 weeks upto now and hopefully he'll just test and say yes it's a ring then the 30a fuse can go in.
Thanks for the reply.
Your right pal I'm not a spark but I'm not a numpty either if you know what I mean. Yes I do have a multi meter. In your opinion is it something I can do with the help of good people like yourself ?
For reference this is not for a job but just to help my pensioner in laws out as it appears someone has, like I said, put a 15a fuse into a 30a carrier. I just want to sort it for them so they don't lose all sockets as they currently have done 4 times in the last 3 weeks.
Thanks for any constructive advice I really do appreciate it.
Best thing to do would be the below.
You are right as in no they wouldn't have to produce a minor works for a plug in boiler. A professional firm would have provided a switched FCU hopefully on a dedicated circuit with a minor works or EIC.
Dedicated circuit for the boiler? Is that more professional? Why is that?
Get an issue on your sockets and you've also got no boiler.....for a more professional job surely it's better to split as many items as possible, within reason. I know I'd much rather (& I consider it more professional) have my boiler on its own FCU and ideally it's own circuit than on a plug top (which is what I said, with out you paraphrasing).
Tameside
How to check if a fuse feeds a ring final or 2 radial circuit
247 handyman,
247 handyman,
