Discuss How to check if a fuse feeds a ring final or 2 radial circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the reply.
Your right pal I'm not a spark but I'm not a numpty either if you know what I mean. Yes I do have a multi meter. In your opinion is it something I can do with the help of good people like yourself ?
For reference this is not for a job but just to help my pensioner in laws out as it appears someone has, like I said, put a 15a fuse into a 30a carrier. I just want to sort it for them so they don't lose all sockets as they currently have done 4 times in the last 3 weeks.
Thanks for any constructive advice I really do appreciate it.
You are right as in no they wouldn't have to produce a minor works for a plug in boiler. A professional firm would have provided a switched FCU hopefully on a dedicated circuit with a minor works or EIC.Presuming that's a minor works notice. Would that be necessary as the boiler just plugs in to a nearby socket
Best thing to do would be the below.
Is this possible with a multimeter and a loopcheck socket tester
Dedicated circuit for the boiler? Is that more professional? Why is that?
Reply to How to check if a fuse feeds a ring final or 2 radial circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
