Discuss How to check if a fuse feeds a ring final or 2 radial circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the reply.
Your right pal I'm not a spark but I'm not a numpty either if you know what I mean. Yes I do have a multi meter. In your opinion is it something I can do with the help of good people like yourself ?
For reference this is not for a job but just to help my pensioner in laws out as it appears someone has, like I said, put a 15a fuse into a 30a carrier. I just want to sort it for them so they don't lose all sockets as they currently have done 4 times in the last 3 weeks.
Thanks for any constructive advice I really do appreciate it.
Best thing to do would be the below.
You are right as in no they wouldn't have to produce a minor works for a plug in boiler. A professional firm would have provided a switched FCU hopefully on a dedicated circuit with a minor works or EIC.
Dedicated circuit for the boiler? Is that more professional? Why is that?
Get an issue on your sockets and you've also got no boiler.....for a more professional job surely it's better to split as many items as possible, within reason. I know I'd much rather (& I consider it more professional) have my boiler on its own FCU and ideally it's own circuit than on a plug top (which is what I said, with out you paraphrasing).
Reply to How to check if a fuse feeds a ring final or 2 radial circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
I have a customer that requested kwh meters on the socket circuits of an office lock he rents out,(rooms are rented separately). There are two...
Hello all. I have just bought my first house but it needs a bit of work. I am re-wiring it and I've found the conservatory ring has been spurred...
