When testing lighting circuits that contains multiple fittings connected to the circuit via plug in roses, are the readings for either R1R2 or R2 taken at the plug in rose or the fitting?
This question is aimed more at doing a periodic rather than at the initial verification stage. Personally I have always seen the plug in rose and flex connection to the fitting as an inspection, as its not fixed wiring, but may be wrong.
Thanks and hope for some help full contributions:helmet:
