Hi
I’m in the process of swapping over a fluorescent light to an LED light in my fathers garage,and stupidly forgot to take a photo of the wiring before I disconnected the original light?.
I’m wiring it in through a connector block as he wants the option of maybe adding another one at a later date. My question is could somebody please help me regarding connecting the wires?
I’ve attached some photos which I hope will help
Which coloured wires need to be connected together? I should add it’s a one way switch in the garage. A big thanks in anticipation
Craig
The blue with the brown sleeve is live, blue is neutral the green/yellow are earths. What do you mean connecting by connector block.
what he said^^^^^. and the 2 browns stay as they are, not connected to the light itself. make sure the earths are connected together. (probably a terminal marked E in the light for these).
Is that 32amp rated joint box your connection block?
and...Will you have access to it on completion?
needs replacing with a smaller one. or even better a quickwire . it's accessible surface mountedon the timber.
The surface clipping needs tidying up too.
agreed . the clip nails should be below the lower cable and above the upper cable. they'e cables, not railway tracks.
United Kingdom
United Kingdom
Light wiring help required
Lighting Forum
RockyS,
cloverman,
