- Reaction score
- 17,140
I think a hole in the ceiling will be the only option.
Is the flue going up through the ceiling?
If so there will already be some disturbance of the ceiling anyway that you may he able to coordinate with.
Discuss Metal blanking plate to protect from wood burner stove? in the UK Electrical Forum area at ElectriciansForums.net
Ooh, snap!The way to protect something from radiant heat is to put something reflective on the front to minimise the amound of heat absorbed, then an insulator to prevent whatever is absorbed penetrating, then as little as possible behind so that heat that does get through the insulator can dissipate.
When we got our narrowboat there was just a metal reflector panel behind the wood-burning stove which did get painfully hot. When we upgraded the stove some 10 years later, we removed the metal and found signs of scorching to the woodwork behind. We put Supalux heat-resistant insulation board in its place and tiled it, and poked a thermometer in the wall cavity to check it was at a sensible temperature.
Yes, it is. I'll have a closer look when next there. I completely forgot about it today when with the customer as we were talking about other bits he wants doing.Is the flue going up through the ceiling?
Reply to Metal blanking plate to protect from wood burner stove? in the UK Electrical Forum area at ElectriciansForums.net
