Search the forum,
Discuss Questionnaire to do HELP in the DIY Electrical Advice area at ElectriciansForums.net
M
Maserati
Hi guys I need help to answer some question because im a beginner electrician and I have 38 question to RE-DO so if im going to stuck I hope I can get some help because my english is not very good and It may be the reason to stuck in the question
1 Why do you need to inform others of your activities which may have impact on their work?
Such as: the need to temporarily disconnect a shared resource like electricity or compressed air supply, making undue noise or creating sparks, fumes or arcflashes from welding.
Hint: Think back to the questions about your safety responsibilities when working with others.
Would you turn the power on for a heating system without telling the plumbers who are working on it? What might happen if you didn’t?
2 How do you deal with disagreements with others in ways which will help to resolve difficulties and maintain long term relationships?
Hint: What does it mean to compromise?
How do you agree a solution when there are two people or more who have different needs / ideas?
I did the question two but it has to be realted to electrical workshop and I have no idea what to write
Can I suggest you apply to the training section, you will find more help in this section.
Reply to Questionnaire to do HELP in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Novice here wondering what I might be missing. Thanks for any help. I am swapping out an old switch in the bathroom to a dimmer switch. When I...
Good Morning need some advice please. Yesterday went to change a light fitting in hallway. There are two ceiling lights in the hall controlled by...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
