Currently reading:
Replacing MK Consumer Unit. Main switch position
Discuss Replacing MK Consumer Unit. Main switch position in the UK Electrical Forum area at ElectriciansForums.net
Taylortwocities
Supporter
Hello mates. i have an MK CU to replace. As you may know, the main switch in MKs is on the left hand side.
There's no way to replace the meter tails. Is there another manufacturer that has a left-hand main switch CU, or a flexible position option?
Thanks muchly!
Thanks muchly!
I would use Fusebox with rcbo's.
I try and stick with same make as one of my peeves is having a box full of various make mcbs/rcbos etc taking up space in the van all it does is seem to grow.
Fusebox populated spd sp+n rcbo boards are decent for the price.
I always keep my eye out on flea bay for unused rcbos etc as I’ve had some good deals.
I don't recall seeing Fusebox being configured with a left hand main switch??
MK is in fact a well-liked option. However, Hager is a manufacturer that provides versatile position possibilities if you're seeking for alternatives. Their consumer units provide you the option of placing the primary switch to the left or right. You'll have more installation freedom in this approach. Hope that was useful.
Reply to Replacing MK Consumer Unit. Main switch position in the UK Electrical Forum area at ElectriciansForums.net
