Currently reading:
Shower
Discuss Shower in the UK Electrical Forum area at ElectriciansForums.net
DuaneMHunt1976
I installed the wiring for the shower, not the shower
the customer got it out of a closing down sale at B&Q
Turned it on FULL to see how it handles, had my hand in the water
i could feel it stop for a millisecond and then go again
also it didnt Burn my hand even tho its 10kW
and it went How (Warm) to COLD.
I did talk to someone about this and they suggested it was the water Presure wasnt high enough
I am not that good at looking around the net for such information, and wonder if that was ture
i set it up on the MAX power to see if it could hold it, because they said it had tripped the MCB.
I think it was A MITE some thing shower
and the middle setting was ECO so i set it one above that
then put the Temp Control to all the way in the RED.
I wanted to strees it out,
How is this your problem if you didn't supply or fit the shower.
Voltage present ? Tick ! Problem lies with the installer unless of course you are getting paid to troubleshoot.
What Andy said but for your own piece of mind just crank it down of the red stop and leave it for a couple of mind, could be the controls are a bit off.
Pretty much hit the nail on the head with this statement...
yes i am stil trying to get paid for the job...
Just trying to CUT out all ELEMENTS for NON Payment. Because i may have to just quiet and get my FLT Driving test done again.
I think what Andy was getting at is were you paid for installing the shower circuit only? if your customer supplied the shower unit it's his problem, get paid for installing the circuit, tell matey to go to B&Q and get a replacement, then charge him again for refitting a shower he bought himself, I f I'm wrong Andy sorry.
i am spose to be getting paid for it, i had to pay for the CABLE MCB SWITCH and still nothing.
am wondering if i should just take it all out again
Land Lord didnt do a Periodic testing when he got someone in
Smoke alarms are from 1999 and never been changes and damaged.
i think i should of looked more around and say no to the job
I don't want to ask how much they owe you mate but you may be better off in the long run if you bite the bullet and say that you are not looking onto the shower fault until you get paid for the initial job.
I am SORRY to say YES, like a PLANK (and i will be flogging myself as i have been most of the week) for doing so, so quick.
Duane, we started off by talking about a shower that didn't work, now we are on to EICRs and smokes, don't want to sound smug, what was the total work content,and what did you actually agree to do? sounds to me like you may have bitten off more than you can chew.
just the shower.. cable, wire and MCB.. that was it.. i do tend to go OFF TYPIC as lot of things get linked in my mind
just going to cut my loses on this.. just dont like leave ANY problems my fault or others
You have given the person the cert, which I presume says everything you have done it fine. Tell the guy the job your quoted for it complete and to the regs and you would like to be paid now. If you chose to look at the shower fault after you have been paid for your initial word then that is up to you.
Fix it? If he has powered it up then he also needs to set it up unless the plumbers was there with him and they could have done a little job sharing.
The OP didn't install the shower. It was not his job to install the shower. The shower was fitted by someone else. It's them who should have tested the shower fully when they installed it.
But if they could not test it due to the electrician not having connected it yet?
It doesn't take long to read the instructions in commissioning the shower and follow the normally simple steps.
The symptoms described sound reminiscent of Mira commissioning procedures,
The OP hasn't stated who installed the shower. It was his job to install the new breaker, cable and that is it. (that is what I get from post 1)
I suppose someone's got to turn it on for the very first time, and will need to follow the manufactures instructions. As davesparks says, it might be a commissioning error. If it is, it's a simple fix and OP can get his money.
I assume you’re talking about a Mira shower. Before you power them up, with the cover off, you have to press a little button to bleed the air out of the reservoir. Some have a thermal reset on them. The shower might not be fubared yet, but unless you tried this, there is no way of knowing. The only time they really go wrong is when a plumber fits the shower and then solders the pipes to it. It knackers up the seals inside them.
Reply to Shower in the UK Electrical Forum area at ElectriciansForums.net
