Currently reading:
Single Phase 2 Speed Pool Pump Motor Question
Discuss Single Phase 2 Speed Pool Pump Motor Question in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone
I came across a single phase 230v 2 speed pool pump motor the other ay and became obsessed with how they work and are internally connected , but cant seem to find a diagram/pic of the anywhere. I decided to do my own from what i found on line
My question is have i interpreted the connection of the windings correctly
are they in series or parallel
Thanks in anticipation
I would say that is the manually operated equivalent of the T106 timer. The motor from which I showed the image of the dual centrifugal switch in post 11, had a similar speed selection switch on its terminal box.
Reply to Single Phase 2 Speed Pool Pump Motor Question in the UK Electrical Forum area at ElectriciansForums.net
