gazdkw82
I thought having one of those socket adaptors that allows you to push your testing leads directly in.
What's the general consensus? Do they conflict with testing resulting
think the one Iv looked at is made by kewtech
They don't , but sometimes if the socket contacts are grotty it can affect the readings. A quick plug in and out sometimes cleans them.
If you get one that reads high ,drop the plate and measure both ways and you will soon see the effect.
I have a socket and see one. It's OK and has its uses. One thing I have noticed is that the figures can dance about it, often with the lowest reading achieved by gently squeezing the two probes together whilst they are plugged into the adaptor. Also have the lighting adaptors by the same brand and have had similar issues with them. Basically they appear to be cheaply made and constructed.
Far better to test at the terminals behind IMO.
I use them for the quick check , but I have already tested a few at the terminals, any high readings that wont come down and the direct readings are ok ; I change the sockets . That is if it is test and remedial.
Don't forget to null the leads and the adaptor when doing your continuity tests tho
I always null the adaptor and leads with my long nose pliers. Still find the quality of the contacts are poor, and that's with new leads that are spot on with croc clips.
Either the E14 or E27 adaptor unscrewed from itself when I was using it once. Very poor soldering underneath.
Not if it's compatible with your MFT leads, which it ought to be.
The pointy bits on the end of my Kewtech leads are..........very pointy. I can get as variable readings with a Kewtech R2 socket adaptor, as I do placing the said pointy ends onto the terminals on the back of a socket. If I'm at all worried by the readings, off comes the socket, to be replaced by bare connectors and use the crocodile clips. That doesn't happen very often :-). R2 socket shoved in & out a few times, normally resolves the issue.
I hear what you are saying Mid. I find if the probe tips are placed really firmly on the terminals the figures don't dance around too much. Maybe my socket and see thing is not the best. I usually put the plug in and out a couple of times before testing. Especially on older looking sockets. :smile5:
A quick blast of this followed by shoving the socket adaptor in & out a couple of times should sort it.
ae235
gazdkw82
leicester
United Kingdom
Electrical Engineer (Qualified)
Socket tester adapter thingy
Electrical Tools and Products
gazdkw82,
davesparks,
