Davidobaynes
Evening all,
At work today we energised the newley rewired lighting circuit, only to find that from 3 lighting points onwards, the lights didnt work. Thought maybe disconnected neutral or line conductor. This was not the case, all connections sound.
Disconnected the neutrals at the 4th light and found 60v on one neutral and 230v on another. Replaced the cable between the 3rd and 4th light, so at the 4th light there should just be the line and neutral from the working 3rd light and the line and switch line down to switch. But the 4th light still did not work.
Any ideas ????
I reconnected the line and neutral to the 5th (so the rest of the lights on the circuit were reinstated) and none of them still worked but still had these voltages, this is the 1st fault to beat, not happy haha
60
Volts is an unlikely result. Try measuring it again with an analogue tester (assuming you were using a digital one).
230 V on the neutral suggests a bad neutral connection somewhere in the circuit.
more like no connection marvo...bad would show a voltage...but 230?
My apprentice did some more fault finding on the circuit and he said he found, he had the neutrals disconnected at the 3rd light but he was still getting voltages at the 5th light neutrals, im not sure if this was correct but will check tomo
Its 3 plated, think ive just gotta work through the circuit light by light, annoying though because all the fittings look to have gd connections and look sound, will be sumthing simple though i bet
Strange voltages
Davidobaynes,
Octopus,
