his tea on the table when he gets their .What exactly is he/she going to be inspecting?
that's personal you should not show them that .next they want to see if you paid you taxes on time .also wanted to see example quotes and invoices
now what is it to be !I showed him an estimate for an outbuilding supply / board which stated the maximum design load ....
if in doubt you can ask them has well, they are their to make sure that you are compliant set down with the building control and the regulations. good luck.while your doing this you will be asked more technical questions
the Brown envolope.Nobody's mentioned money yet![]()
