W
whazza22
Hi there,
I was testing the supply of a fridge with a voltage indicator.
I tested the incoming suppy which was fine but when I tested the terminals on the compressor it tripped out the mcb.
Why would this happen if Im using a voltage indicator and not shorting anything out as such?
Hi there,
I was testing the supply of a fridge with a voltage indicator. Was this a Neon/Volt stick/ Multi-meter/ voltage tester.
I tested the incoming suppy which was fine but when I tested the terminals on the compressor it tripped out the mcb. MCB/RCD ? Some voltage indicators do trip RCD and you can buy ones that can test without doing that, so was it your MCB or RCD that tripped.
Testing Supply of a Fridge..
Australia
whazza22,
malcolmsanford,
