Hi,
I have a standard single ceiling light that I wish to convert to a set of three light fittings, physically right next to each other and controlled by the same switch.
What is the correct (and preferably easiest) way to connect this up?
Kind wishes - Patrick
It all depends on what type of fitting and how the current light is wired up and what the new light fittings look like.
You could use a wago box and wago 221 terminals for the wiring...
Can you post pics of the new light fittings and the existing light wiring. Make sure you switch off the power to the light at the CU before messing with the fittings.
and take a photo of the connections before you diss anything
I'll repost the pic if you dont mind... rather than going into your dropbox...
So the 3 red wires are permanently live.... These will give you nasty bite, so please isolate at the board.
Also, when you disconnect, watch that piece of brown sleeving doesn't slip off.
The best way is to replace this with a joint box hidden in the ceiling, and running a twin and earth cable to each of the 3 new fittings, connected to where the pendant flex is here... (outer brown and blue)
Make sure the earthwire is also connected, even if your new fittings dont require it, it still needs to be present at the new positions.
You've made my day! That was how I was going to do it. I couldn't see anything unsafe with doing that but my background is in electrical engineering, not domestic electrics, so I thought I'd better check on here to make sure I'm not falling foul of wiring regs.
Thank you very much for the advice and to all who have read and/or commented on my post.
- Patrick
A follow-on question has occurred to me: do I need to run the same gauge wire as is used in the ring (2.5mm?) to each of the light fittings? I'm guessing maybe yes because no fuse is involved anywhere but it's going to be a fiddle to get all the wires into my junction box (reminds me of a certain film: "We're gonna need a bigger junction box.").
Just had a look at the Wago box. Not seen that before. Thanks for the tip!
Only builders wire lighting in 2.5mm2 twin & earth, as they only carry one size of cable!
More seriously, if this is a lighting circuit on a 6A MCB (or RCBO or 5A fuse), then you can wire the new fittings in 1.0 or 1.5mm2 twin & earth.
2.5 cable, spurring from a rose on a normal ring?
Using such terminology, I must admit, I'm hoping OP has some serious engineering skills and isn't taking the pee.
Looking at that rose photo, I never can understand why people 'double up' without using available terminals! Look at the damaged screwheads, 2 completely perfect!!
No lighting is wired in 1.5mm2 twin and earth and make sure you sleeve the earth conductor with green and yellow sleeveing
With some of the LED drivers these days it is better to use 1mm instead of 1.5mm as they are a pain to get the conductor wrangled in to the terminals.
North Yorkshire
What is the correct way to spur off a ceiling rose on a normal ring circuit?
Lighting Forum
EasyGoingPat,
littlespark,
