- Mar 14, 2013
- 25,716
- 18,746
- 18,688
- 79
- United Kingdom
- Retired Electrician
- Business Name
- None
What about mains smokes/heat detectors with it being a rental? I know it's not a requirement in older houses but if you change the cu do you need to bring those up to current standards as well?
I think you need to ask the question as to why you are changing the CU? it's not because it's not to the 17th, its because it's in a dodgy position, but remember before you move the CU there is an important task to complete before you change it.
