Discuss Kevin please change careers before killing someone in the UK Electrical Forum area at ElectriciansForums.net
Suspect he might have been a plumber to start with because he is certainly no electrician!Hopefully Kevin gets zapped on his next job and moves on to plumbing.
i don't think that even a plumber could be so stupid. a builder perhaps. either way kevin needs a 25 mm tail shoving up his arse with 240V applied.
I know a few builders who would be very upset by that unnecessary comment.
No I think Arse will be sufficient.I know, he should of used the phrase buttochs
Somebody whos an extreme cowboy is not even fit to work as a burger flipper.Hi,
If you're a spark, you're reading this, your name is Kevin, you work in the Manchester area and you did a job in Rusholme yesterday on lights that kept tripping the RCD - Please reconsider your career before you do serious damage.
It's forgivable that you were unable to diagnose an insulation fault with the lights and blamed it on a faulty RCD (though the customer said you thought it was both RCDs which should have made you think again). I presume you don't have the right equipment for insulation & RCD testing?
It's also forgivable taking the lights off the RCD as a tempary measure.
What isn't forgivable is taking the 1.5mm lighting circuit with an insulation fault on it, taking it off the 6A breaker and putting it directly on the main ccu switch protected only by the suppliers 100A fuse! To compound matters you didn't even put it on the consumer side. Instead putting it on the supply side so when the customer was getting a firework display last night - they couldn't even isolate the electrics!!!
I don't know how much current was going through the light fitting but even the copper had disintergrated.
I seriously believe if I hadn't attended at 1am this morning there wouldn't be a house still standing.
I tend not to call scaffolders any names, especially the ones with big calloused hands.We all name call other trades , It's called banter . Don't take it too serious.
even the ones with soft cissy hands can drop a hammer on your head from 40ft.I tend not to call scaffolders any names, especially the ones with big calloused hands.
Reply to Kevin please change careers before killing someone in the UK Electrical Forum area at ElectriciansForums.net
