From what I understand,it has been one delightful diy find after another since they bought the house.That may be the reason why the fault was left in the first place the customer.
Discuss Fault on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
According to the board there is one circuit for kitchen sockets. The customer has shown me the sockets that they are aware of. I’ve asked about fcu’s etc and they reckon none. I’ve had a look in cupboards etc and I can’t see anything else.Have you actually found which of the four legs of cable in the ring has the fault on it as reading the posts Gavin (post 8) suggested this as it is not clear to me? Is there another ring in the kitchen as three sockets don't seem a lot.
Hence my approach of put new in,save myself hassle and time. The entire install is a mess.I wouldn't trust that for a start ........... nor the client ....
I’ve got a feeling that there’s a big adaptable box somewhere,with a birds nest of jointed cables in it.There is many a job that we would like to do that, but this is part of being an electrician this is what we are trained to do.
Makes you wonder if the customer is telling you the whole truth and nothing but the truth, since he was the one who pointed to the Kitchen RFC in the first place.From what I understand,it has been one delightful diy find after another since they bought the house.
Well how he came to the conclusion is the way we would. Knocked all the mcb’s off then turned back on one at a time till he found the one that tripped. Or at least that’s what he told me!!Makes you wonder if the customer is telling you the whole truth and nothing but the truth, since he was the one who pointed to the Kitchen RFC in the first place.
I don't see why the OP is getting some hard time on this approach.
Thanks for the support in my approach. Obviously in an ideal world,locating the fault would be great,but in this instance I just think it’s easier to put new in.I don't see why the OP is getting some hard time on this approach.
If it's quicker & less costly to rewire the RFC, I would do the same. He could spend the time locating the fault (or not), but it also might leave some poor joint or other unseen poor installation. Least he can leave it this way, in the knowledge that it as near perfect as he can achieve.
We all know that randomly replacing parts isn't a good idea ... and if there are really only 3 sockets identifying where the break is shouldn't take long ............. 2 radials anyone?
I am still awaiting the OP to say where the fault is? assuming he has located the leg which has the fault.
Once I IR tested it,and it came back with a virtually zero reading,I didn’t split it and investigate any more. Again,looking at the state of the current install,to me it would be better to just put new in. The customer only wants 3 sockets. 2 of which I can drill straight through from the garage and the other straight through a void in the floor. Then when done,I can rest easy in the knowledge that the entire circuit is 100%. No hidden nasties anywhere else,waiting to go wrong further down the line,which will result in me having to go back.I am still awaiting the OP to say where the fault is? assuming he has located the leg which has the fault.
Thanks for the reply, now you have explained it seems the easiest option and best action.Once I IR tested it,and it came back with a virtually zero reading,I didn’t split it and investigate any more. Again,looking at the state of the current install,to me it would be better to just put new in. The customer only wants 3 sockets. 2 of which I can drill straight through from the garage and the other straight through a void in the floor. Then when done,I can rest easy in the knowledge that the entire circuit is 100%. No hidden nasties anywhere else,waiting to go wrong further down the line,which will result in me having to go back.
Once on site I’ll take some pictures of the job which will hopefully paint a clearer picture. I know sometimes it’s hard to visualise what someone is putting in words.Thanks for the reply, now you have explained it seems the easiest option and best action.
The only possible problem I see with putting in a new circuit might be if the original circuit feeds other points somewhere else besides the kitchen. If that's the case, disconnecting the existing kitchen circuit would leave any such points dead.Once I IR tested it,and it came back with a virtually zero reading,I didn’t split it and investigate any more. Again,looking at the state of the current install,to me it would be better to just put new in. The customer only wants 3 sockets. 2 of which I can drill straight through from the garage and the other straight through a void in the floor. Then when done,I can rest easy in the knowledge that the entire circuit is 100%. No hidden nasties anywhere else,waiting to go wrong further down the line,which will result in me having to go back.
The customer hasn’t told me of anything else being off but I’ll certainly double check!The only possible problem I see with putting in a new circuit might be if the original circuit feeds other points somewhere else besides the kitchen. If that's the case, disconnecting the existing kitchen circuit would leave any such points dead.
My own professional curiosity (or maybe just my OCD!) would not let me give up before I'd found the reason for the fault.
But that's just me...
Reply to Fault on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
