- Reaction score
- 4
hello all is this possible????
I drive a van around all day, I want to use the van to charge up a 110ah Agm battery, I then want to use this battery to power up a 12v led lighting circuit in my house. I also want to use the 240v supply as a back up to the same lighting circuit, with some sort of switch over device for when the agm battery voltage gets low.
Essentially I will have 2 batteries in rotation, charging one all day why the other is being used
Any idea if this set up is used any where and how well it works, or where to find the calculation to see how long a fully charged 110ah battery would last
I don't want to use a inverter, just the transformers already build into the Selv lighting, and diodes to stop the 240v system back feeding into the 12v system.
Is this possible, (not too bothered about it being economical)
Let me know your thoughts and criticisms
