Snap on, are they a kind of shop like Ann Summers?
No. Snap On sell metal things, Ann Summers sell rubbery things.... according to my mate...
Reactions: ruston
can't fault snap-on.they repaired my ratchet screwdriver, 30 years old. FOC.
My old place was fitted out with snap on kit, a socket split once, they replaced the entire lot, it was years old, a tad expensive on shirts tho, I always drooled on mine, usualy at lunch time for some reason.
It's just personal preference but I think it's good to try all options too. I have the knipex installation pliers and they work for me. Many tasks can be performed with them. However some people hate them.
I settled on these after trying all options. I still use the automatic strippers if I'm doing lots of cable stripping. Iv used side cutters and had similar issues to what you describe. Iv tried cable cutters, adjustable insulation cutters etc etc.
It really helped working with them all because on my recent AM2 exam I only had side cutters. Good job I knew how to actually use them, even if I dont on a daily basis.
So on the exam that's all you're allowed?
No. There are many tools including pliers/grips/cable cutters etc. The side cutters were the best options for stripping I found.
Sorry I'll clarify. I know there would be other tools, I was just curious if they allowed you to just bring your own tools, so you could use what you prefer or whether you just had to use what they provided
The centre I did the assessment at didn't allow you to take anything in. Even have lockers for your phone/wallet etc
Reactions: MeggerHertz_NW
There's many ways to skin a cat (not that I'd ever skin a cat. I love mine).
There's many different approaches to sripping. Evetually, you develop a bit of a "muscle memory" for it, and it's different for everyone.
I like to use CK redline cutters with the notch in for t&e. But i also know chaps who use cable loppers and side cutters.
Simialrily, I like to use a knife for circling around round flex outer insulation (many will gasp, but i've done it this way for years and my hands have done it that many times, I just know "the right feel" to stop it going too deep - plus I still always check each inner core individually for nicks even after all these years)
In short, you won't get a solid answer. Just try a few tools, try on lots of scrap cable and in time, you'll get a system that works for you wthat you won't struggle with.
When I was at college many years ago, we used a knife to strip cables, always used me side cutters on site. lol
Having read all the various posts about dedicated stripping tools, pliers or side cutters, of which I have various examples collected and used over the years...
There is one method that hasn't been described in the posts as far I can see for side cutters, to strip ready for termination.
I was shown this method at college 35 years ago, it has stayed with me, is simple, quick and effective. It works for all types of side cutters with insulated single or stranded cores to 2.5mm.
(my preference is for smaller Lindstrom flush-cut cutters for smaller thinner gauges, because of the work I predominantly do)
The method is a variation on squashing the insulation, perpendicular to the core but only sufficient the crease the insulation without getting close to deforming the conductor.
Next use the cutters to nick the insulation at the edge of the crease line to close to the conductor. This effectively puts a cut in the insulation allowing it to part easily. Put the cutters back across the cable on the crease line, apply firm pressure, just a little more than you did to crease the insulation allowing the cutting edges to bite in, but not enough to catch the conductor and while maintaining this pressure push the insulation off the conductor.
I hope that makes sense. With a little bit of practise, it's as quick as an automated stripping tool.
problem is your muscle memory, adapts slowly over time as your cutters loose there keen cutting edge. then you buy a new replacement set, same make, same size and for a whole morning, most wires you strip become an inch shorter!!!
There is one method that hasn't been described in the posts as far I can see for side cutters, to strip ready for termination.3
Interestingly @Jon_iz the method you describe is one of the methods I use day to day - (or at least once I have removed the outermost sheath of a flex using my method). Yours is actually the earliest method I remember of being shown to strip cables by my father.
Curiously, I use the same flat lindstrom cutters you describe as I do a lot of work with control cable and find them great for a flush cut (they come into their own when terminating an rj45 plug)
Which is a point in itself - lindstroms are £35+ a go. Quality tools make all the difference. Mine must be 17 years old now and still razor sharp.
I find I alternate methods a bit however depending on exactly what job I'm doing, what feels right and what day of the week it is.
This will not be popular, but it must be me, reading all the answers on here, aren't side cutters just that, they are designed to cut things, I have always used a dedicated wire stripper, IMO I would not trust a mechanic who used a pair of pliers to undo the nuts on my car, does the job, but is not the correct tool, but pliers may have to be used if some muppet has used them previously. One caveat, side cutters with notch's in are in effect wire strippers. Now days weak old Arthritic hands make these my go to tool: C.K Automatic Wire Stripper - https://www.toolstation.com/ck-automatic-wire-stripper/p42984 when I do anything for myself that is.
for flex I use a rotary stripper. far easier. set depth. spin round a couple of times, pull off sheath.
Reactions: Pete999
Always filth with you Tel.
I would use a pair of CK cable cutters, these are what I have used for over 20 years.
If you need teaching with how to use cutters for stripping conductors there is little you can be taught
I know people who have found that after they accidentally cut through a live cable it blew a lovely sized hole in the centre of the jaws, that really helped them with their stripping technique;)
Email
Time zone
Last seen
Stripping Wires With Side Cutters
MeggerHertz_NW,
Soi disant,
