J
Jon Hodgson
Hi Guys I've been posed a bit of a tricky question with regards to installing a consumer unit into a stud wall the client has asked for it to be recessed back so that only the removable lid is protruding from the wall. But doesn't want to got to spend out on a recessed CU which best price I can get from the wholesaler is about £190 exc VAT before the breakers are considered.
The question asked was am I able to install a Plastic CU into the wall and mount it onto a board between the uprights of the Studs. A board could be fixed in between the studs and a that section left open and free from insulation to allow air flow.
I'm at a bit of a loss to the answer my initial reaction was that its a possibility, but then thought it might be a good idea to use a metal clad board if this was going to be the case.
Any help and suggestions would be appreciated.
