Discuss Hello All, need a little advice in the The Welcome Forum area at ElectriciansForums.net
I've come across a job wherebut it isn't lighting up, however if you trip the MCB, then the emergency back up kicks in and it is lighting, anyone come across this before?the emergency bulk head is wired direct to the CU,
Cheers Jools
The client says that, the fire brigade told her that it has to be lit at all times, there is another switched light in the area, so this seems a bit OTT.
The CU is a twin RCD board, when one RCD trips, then the emergency light comes on, never seen electrics like this place before.
so the em' light needs to be linked across to the lighting circuit?
Reply to Hello All, need a little advice in the The Welcome Forum area at ElectriciansForums.net
