R
rsmck
My usual disclaimer applies - I'm not a professional electrician..
I recently changed the CU in a family member's home as a bit of a stop gap (they are building an extension later next year and will have the property fully rewired then - but for now they asked if I could replace the traditional rewireable fusebox with a modern CU with RCD protection)
One room (not a hall stairway or anything like that) has two-way switches and the irritating issue of a borrowed neutral. I know the 'proper' solution is to provide a new neutral - but as the property is being rewired in a year or so anyway and there's no easy way to run this in without extensive redecorating it's wasn't a viable option.
I've put both the upstairs and downstairs lighting circuits on the same RCD (again, would rather not, but it means they have light!) and marked the new CU with a note stating that the lounge lighting has multiple means of isolation and the relevant circuit numbers.
Is there anything else I could do to improve this situation that I may have overlooked ?
As an aside, replacing the CU also showed two FCUs which, when fitted initially, appear to have had a screw cut into the insulation of the live cable. Presumably these screw heads have been live for many years and no-one has touched them, but certainly made replacing the CU worthwhile
