- Reaction score
- 5,633
I always seem to come across the same problem when installing outside lights, where to get 1mm black rubber flex?
Preferably I'd like some 3183p (1mm) but can only find 0.75mm or 1.5mm.
Happy to use 3183TRS or 3183VR but also struggling to find that in 1mm.
Farnells are usually good but they are out of stock.
What are other peoples preferences for using cable outdoors for lighting? Would you be happy with black PVC flex?
Also if using 0.75mm flex on a 6A MCB would you fuse down? 0.75mm flex has a CCC of 6A so in theory its fine but just seems a bit close?
