E
exon16m
barn roof opening height 3m.
Corrugated cement roof ? asbestos not sure how to tell lets assume it is at moment.
4kw installation needed with tier A setup
have two separate meters at address one for annex and one for main house so have been advised could get two installs.
Have a quote of about £6k inc vat (+ scaffolding) per install.
Can anyone match/better this?
Re: Barn installation needed 2x4kw on same roof ? asbesto in Sussex area need some qu
6k?? They can do my installs for that
Does that include asbestos check and drilling?
Does that include a structural survey?
How far is the barn from the supply?
Fitting onto a commercial roof is very different to installing on a domestic roof, also with the cost of cable, it is important to calculate this correctly, barns are normally quite a distance from supply, and I am aware that some do it but to string a length of 2.5 or 4mm cable over a distance just causes problems, and then they blame the DNO for over voltage.
Have you thought of installing these as a commercial project?
There are many benefits if you have the correct advice.
Sorry, but I would not entertain installing 2x4KW systems for 6K each including VAT on a barn roof, but I could install 2x4KWP systems properly.
what is the benefit of a commercial installation? roof is 22.5m x 6-7m to apex perfect south face and 20 degree slope
Barn has power and beaker inside that link back to house
I really do not mean to sound rude, but without a site survey it would be impossible to price, especially if you are looking at spending 6K per system.
The link back to the house would probably not be suitable for a PV installation, and you certainly could not run 2 systems down 1 cable, if you see what I mean.
Where are you in Sussex?
burgesshill haywards heath area
We cover that area and as part of a large roofing company would always recommend an overclad with that sort of roof unless you don't mind the odd leak in a few years time? either way you need to have the inside either netted or bagged before anyone sets foot on the roof. AC runs to barns are rarely man enough for pv systems unless they were installed with machinery in mind. 2 meters is not enough to get 2 higher tarifs, they need to be addressed differently, although its a light grey area if you phone ofgem!
shameful - why would you use that photo as an example?
Maybe it is their best install, all the others are worse.....
are they? still after taking out the ebay fees they be fitting it for nowt!
on EBAY!!!!
If you want your job done properly, then you're way out on £6k.
much above that the finances dont make the investment pay with the new FIT.
What would you quote?
It depends on a lot of factors.
The structure and condition of the roof, the asbestos survey, the height of the building, the cable supplying the buildings, the use of the building (for reasons of working safely with asbestos) etc.
Installing on a corrugated cement roof is very, very time consuming and extra safety measures are required - especially so if the roof is found to have asbestos content.
Are you planning on installing two systems at the 21p per kWh FiT rate? If so, I very much doubt that you'll get the full rate for both systems.
Ok, there are lots of ifs here, but using the SAP formula for a 4KWP system, if you have the perfect roof, if you have the perfect orientation, and if your system produces the amount calculated by SAP (although they can be 20% over depending on location in the UK, quality of install etc)
For a system cost of £8400 total, would save you £997.46, (Fit payment@21p, 50% deemed export, and 50% generated saved from your electricity bill @13p per unit)
Which gives you a return in year 1 of 11.9% index linked and tax free.
Of course that is for the perfect roof, which many are not.
Many people throughout the UK are seeing these types of returns, some are even better, but others do not believe it is possible.
So there you have it
I hope this helps.
what age is the corrugated cement roof?
after 1999 and it would have been illegal for it to have been asbestos, fairly unlikely post 93.
If it's not asbestos then the main issue for me would become whether the roof was classed as a fragile surface or not - some corrogated fibreboard roofs aren't, many should be. If it is then it's going to need protective measures for the staff working on it such as nets. If it's not, then it shouldn't be more expensive than domestic really unless the electrics supply needs serious upgrading (which it often would, and could add hundreds or low thousands to the cost depending on distance and difficulty of digging the cable in).
I'd always assumed that they all are?
8 grand for cheap panels
10 grand for sharp, this should be the going rate for a 4kWp system
earthing gas & water is extra charge as well as distance to travel, scaff inc in initial cost
its not worth putting a 4kWp system on a barn or 2 of them.
when you visit a barn try to pinch the roof material if it snaps clean then concrete and if it pulls away like its mixed with hair then its asbestos.
also asbestos is a dark grey colour compared to concrete which is the colour of a paving kerb.
Don't quite figure how 2k adds to a Sharp system, thats 50 pence per watt premium. Either yuor buying Sharp at a very high price or you are getting very,very super cheap panels.
yes i buy at high prices
so someone explain me this...
Cheep versus expensive panel forgetting density of panel as space is not a problem. Inverter may be a different story.
They are all offering with a large insurance firm a guarantee that the at 10 they will offer 90% and at 25 80% of their first rated power. Surely on this basis a more budget panel is a no brain-er. Who is to say how much further the tec has advanced and the price has fallen. (from electronics industry history both are nearly guaranteed)
All panels are tested under STC (standard test conditions), however some panels perform better in low light conditions, also when the panels heat up.
Some manufacturers use better quality cells, and also power match them, because if have one panel weaker that the others, this will drag the performance down.
One thing that all customers need to remember, they are buying a system that should last for 25 years, and the better it performs the more money you will make over the term.
Panels only make up part of the installation, if companies are very cheap, you need to question why.
Do they test asbestos by breaking a piece off and seeing if it has strands? As this type of roofing is called fibre cement the clue is in the name, and you can not tell by what colour it is....
I gave you my opinion on the roof, but by the sounds of things you are looking for the cheapest possible, I, and many others have seen "cheap", and it always comes with poor quality installs, and problems.
But, may I wish you luck.
Reactions: 1 person
its like a car, they all go from a-b but which one is still going to be running smoothly in 25 years? the cheap one?
All I can comment on is what we are doing: Big names but cost effective panels from manufacturers such as Yingi we are happy to sell. Poly panels not a problem on large roof areas / commercial installs. One thing that we have noticed is that manufacturers (and many do) that quote the +5 tollerance - quite often they quote each panel rating on the pallett and we have never seen this above 1% of STC. All the panels have a very similar rating so we see that these are sorted well in terms of performance. Last year all our commercial installs (mainly farms) insisted on German now they often don't even ask - although we still quote for what we regard as a quality panel these are generally Chineese. Interestingly customers still seem to not question the inverter that much. As this is a major component I always find this odd.
Last year the questions always asked was:
What is the efficiency - you can work this out yourself based on the dimensions and wattage of panel, lower efficiency are larger, again not a problem if roof space available
What is the tollerence - mentioned above although we always use positive tollerence
What is the warranty - not much in it from most manufacturers
What is the inverter start up voltage - quite often used to sell PowerOne over SMA - not much value in my opintion although PowerOne are a more cost effective inverter on the market.
A lot of the above questions that came from the customers, in my opinion, where due to previous 'sales' people clutching on headline figures (luckily not so many of these type about now).
However I do agree with EarthStone that the price only makes up part of the equation as installation quality is very important. We could knock out two 4kW installs in a day if we decided but always allow 1.5 days (generally). Quality matters a lot and also the fact that a fair price for a good quality job should also mean future contact with the installer is easy and they will be happy to answer any queries for you, rather than 'job done bye bye'.
"its like a car, they all go from a-b but which one is still going to be running smoothly in 25 years? the cheap one?"
In relation to panels - who will know, i guess we will have to wait 25 years and see which does and which manufacturer is still about to warranty it?
Should you really take claims on datasheets on performance at face value?
exactly my point but brand can be a poor way of telling this as can location of origin. Most of the insurance is by large insurance companies not the maker should be solid (but who knows in the current climate). I want a good system that is also a good value system.
you get the jist, id put a fiver on a VW still running smoothly over a french car any day of the week. just like a good mid range panel, hyundai, LG, Bosch for example will in IMO be a safer 25 year bet then something un branded and un heard of.
plus everyone knows insurance companies will do anything not to pay out.
so what is the view on Mitsubishi panels? big brand and good price.
Mitsubishi panels - IMO overpriced.
'plus everyone knows insurance companies will do anything not to pay out.' oh yes !
Just a thought but - if you get a panel fail in 10 years from now - how much will it cost to replace? £50 in todays money for the panel? (plus labour of course).
but a good panel if all panels were the same price? and fronius inverters?
yingli 265w panda are great Panels.
Trina 235w if your looking for a good poly.
samsung are good
The warrantee only covers panel performance, so it will be interesting to see how you prove that, plus it only covers the cost of the panel, not scaffold, (netting if required), labour, so choose something resonable, then you should not have a problem.
Just a question to ask but how many manufacturers actually manufacturer everything from scratch right from wafers? BP Solar at one time was a 'big name' brand but from that i read they finish production they got rid of 2,500 staff (worldwide, from memory). When you look at SunTech employing 20k staff I can only think that BP didn't do the complete manufacturing process and a lot was re-branding and taking advantage of it's down brand name for marketing. How many of the other 'big name' brands work a similar game? Would I be correct in thinking this?
'yingli 265w panda are great Panels.' - agreed can't go wrong with any Yingli panel from what we have experienced Poly or Mono both perform very well and although not an exact science to compare with others we have installed (Samsung, SunTech, Sharp, Scott) they have performed even better, but definately as good.
What would people quote to fit a set of panels. I think this would be the only way to get the exact parts I want.
As per your original quote of 6k inc vat + scaffold. Many will know doubt disagree with this but we are fitting 4kw for £6200 inc vat and scaffold and we do a good job in one day most cases. So if you are confident of them doing a good job then in this climate I would say go for it. Interesting isn't it; many will say that 6k + scaffold, lets say £6400 is too cheap but then you get told 9k is too much. I would suggest if you go for this sort of price then get a couple of referrals from them and give at least one a ring and take a look at the job if possible. Also keep an eye on the job and take a look at the roof work + don't pay a deposit. Tesco do 4kW for 6.5k so why shouldn't you get a job for 6.2 that is good from a local installer? You can get ripped off what ever you pay just trust your instincts, don't pay a deposit (not needed at todays prices) and take a look at the work in progress, good luck.
Barn installation needed 2x4kw on same roof ? asbesto in Sussex area need some quotes
exon16m,
exon16m,
