P
pb8
Your thoughts please lads and lasses. I'm assisting a local spark who's is fitting quite a few outside lights to a large kitchen/diner extention. When I've done them in the past I've always managed to get the cable run in line with a socket or switch so the cable is in the safe zone run that extends to both sides of a wall. But in this instance this will not be the case and I think we should run the cables in earthed metal conduit. Local sparky chum says not necessary as it's rcd protected? It will be buried less than 50mm deep by the way. Who's right??
