dunaldo
Hi, i am on replacing a few light switches, from the white plastic ones to new metal ones. i know that i have to run an earth from the light box(which are already earthed) to the switch itself. I have bought some 4mm earth wire, but it is a bit thicker than the wires in the switch already. Is it ok to use the 4mm, or should i find some thinner earthing cable? Any help would be greatly appreciated.
Regards Paul
Regards Paul
