B
bigp26
Hello All!
Before I start, I want to thank you all for your help in advance!
I have recently been refurbishing my flat and decided to replace the storage heaters whilst the builders were in. I opted to replace my old and bulky storage heating solution with some panel headers from the Adax NP range.
What my builder has done, is to convert the fused spurs which previously powered the storage heaters into standard 3 pin sockets and simply plugged my wall mounted electric panel heaters in. This works, however I hate the fact that there is a wire hanging between the socket and the heater (in 4 areas where I have the 4 heaters).
I had asked him to feed the wires for the heaters behind the plasterboard wall, directly into fused spurs rather than fitting a standard 3 pin socket however he had the following comments:
Now I’m not sure whether the builder is either being lazy, or simply isn’t sure about the rules and regulations and guidelines about this sort of stuff.
Your thoughts on the matter would be much appreciated!
Kind Regards,
P.
- The wires for the previously fitted storage heaters were not placed behind the wall so there must have been a reason for this.
- Hiding the wires behind the plasterboard could pose a fire risk as the heater would heat up the cable (nb. maybe 5cm of wire is directly behind the heater. This would be the case regardless of if the wire was placed in front or behind the plasterboard wall).
- The plug sockets are getting warm and therefore it poses a fire risk (nb. I tested this theory and the plug sockets for the 2kw heaters do get very slightly warm after a couple hours of use).
Kind Regards,
P.
