Currently reading:
High integrity earthing
Discuss High integrity earthing in the UK Electrical Forum area at ElectriciansForums.net
surreysparks
Hi all.
quick question, on a rfc wires in 2.5 single or tne, can you use high integrity sockets and terminate each cpc into a different terminal, and same at the db, or do you have to pull a 4mm radial cpc
in aswell.
i learnt that you could just split the cpc at college years ago, but reading up it apparently needs to be 4mm?
also what would you code a computer circuit with no high integrity earthing on a eicr?
Hi all.
in aswell.
Is the protective conductor current likely to exceed 10ma?
Hi all.
in aswell.
I will need to have one of my rare visits to that good book to see if I am about to state a load of bull
The total area of all the conductors in a multi core cable inc the live conductors shall be not less than 10mm
If that is correct then there will be no code for a twin+E ring final even if its used without the sepearate 4mm earth as per a radial
Reply to High integrity earthing in the UK Electrical Forum area at ElectriciansForums.net
