Currently reading:
How to run electric to my shed.
Discuss How to run electric to my shed. in the UK Electrical Forum area at ElectriciansForums.net
L
Lee Duncan
Evening folks,
Im Lee and I am looking for some advice on how to run electric to my shed. I have been searching the net for help but there's been so many different answers its starting to confuse me. I have never tried this before but I am an experienced diy'er and will give anything ago once.
I will be using my shed to fix and build motorbikes so I will be using power tools. I'm wanting to have 3 strip lights and maybe 4 or 5 double sockets.
My shed is approximately 10ft from the back of the house, it would probably be 24ft from the main fuse box. ( main fuse box is located in the cupboard at the front door)
I know I'm going to have to dig a trench to run the wire from the main fuse box to the shed but not sure how deep plus the wire will be run underneath a path, will that be safe?
Can someone please tell me how to do this and what wire, fuse boxes etc etc i will need?
Any information would be a big help as I would like to give this a go myself instead of getting a sparky in.
No not putting them out of work there is plenty of work out there, I am asking for advice thought this would be the best place but by the sounds of it I was wrong. Weather it's here I get the advice or somewhere else I will get it and I will do it myself. Would rather ask the professionals how to do it than someone who doesn't have a clue but well well at least I might actually get the answers I'm looking for somewhere else.
I feel sorry for you, your acting like a wee child you can't even help someone who's asking for advice out, how petty are you!!!
Can you send some my way then?
Lee, the job you're describing isn't a simple one, it requires calculations to be made, an inspection of the site, a look at the current installation, testing properly with an MFT prior to being energised, not to mention certification. I respect DIYers and folk who are willing to have a go, but not with electrics, and certainly not with a job like this, please get a professional in. That's what we're here for!
Ok Lee, fair enough. Step one. Contact your local building control for an electrical installations application for notifiable works, (or the equivalent in Scotland) this must be done prior to work commencing.
In Somerset the application will cost £275, you will be better off contacting you local office as the rules in scotland are
different.
Chris
Lee,
Before you do ANYTHING, please remember, ELECTRICS CAN KILL! Not necessarily you... Maybe your wife, your son or your daughter.
We're all on this forum because we're either qualified electricians/installers or training to be electricians/installers. In other words, we respect the dangers of the trade and know the need for having the proper knowledge to do the job.
Would you go on a doctors forum and say "my mate's got a hernia and needs it sorting, i'm going to give it a go, please give me some advice"...
Crack on Lee its easy mate.Just make sure you do a ZS test at the fuseboard first and ascertain wether your DNO has installed a TNS,TT,TNC or PME system and make sure all the Equipotential CPC is 17th edition compliant.Then decide what sort of cable you want to use its up to you,you can use T+E,LSF,SWA or LV.Make sure you use IP rated glands though.As the work you are doing is classed as being in a special location you will probably have to fit a RCBO into your fuseboard.Once you have selected the cable you are using calculate your volt drop which will tell you what size you need.Dont forget to use diversity when you are calculating the size of your main overcurrent protection device.If you dont know how to do the calculations get a copy of the latest regs book its only £65 and the OSG is really handy as well and thats only £20.After that its simply a matter of wiring it all up.Before you energize it make sure you do an Insulation resistance and continuity test.The best thing to do these with are MFT's you can pick a cheap one up for about £750.Then you will have to notify your local council to come and sign it off.I dont know what they charge in your neck of the woods as they are all different but i know where i live there is a minimum charge of £250.Also you have to notify them before you start work.The worst that can happen is you will have a fire or someone will get killed by electrocution
Or you could just pay a spark to do it
a bit of constuctive advice to add to the previous posts is to get an electrician to give you a quote ( get 2 or 3 quotes ) and see if you can do the donkey work of digging the trench etc. this will save quite a bit on the cost. honestly, with the best will in the world, this is not a diy job. i had a minor operation last year. i could have had a go myself, but thought better of it and got a qualified surgeon to do it.
Regardless of whether you feel "able to have ago", as others have said, supplies to outbuildings come under part P of the building regulations and are notifiable by law. This is because there are many factors which make taking a supply outside the property potentially dangerous. We spend years training as electricians, and with the greatest respect to you, it is not a profession you can simply "learn by doing".
Regarding there being plenty of work.... I can assure you that with more and more people DIY'ing, and many people retraining as electricians with their redundancy money (due to being told that there's plenty of work), the work available is getting thin on the ground.
5m of SWA - £12
Spade to dig trench - £15
Wrongly rated PD - £19
Pack of hob nobs and 6 cups of tea - £3
Look on Lee's face when his shed, beloved bikes and tools go up in flames, PRICELESS.
Back to the OP.
To do this safely and "cheaply" get a couple of sparks round, state you will dig the trench to 600mm etc and let them do the techical bit.
Or could I borrow your lorry later this week to do some deliveries? I've not driven an articulated HGV before but I'm assuming anyone can do it.
Does not affect the op as he comes from Aberdeenshire which when I last looked was in SCOTLAND, anyway looks like he has taken the hump or has understood he has upset aa few people.
I don't know why everyone is taking the mickey out of the OP. Its just 'red to red & black to black' after all.....
On a similar note, to save time and hassle, I going to do my own vasectomy. After all its just cutting a couple of tubes. I have my missus nail scissors and my soldering iron (if I need to cauterise the tubes) and I'm sorted... Will let you know how it goes...
Reply to How to run electric to my shed. in the UK Electrical Forum area at ElectriciansForums.net
