As above how to go about wiring a flurecent light in t+e wih one way switch?
Thanks in advance
So basically this is what i thought a feed to the first light from the borad then looop to the next ligt and on the last flurescent connect in the switch?
OK thanks for the replies so bascally this is what I would do
T+E to the first light fitting link in ma switch live wire to the phase from main board to live termialn the fitting and the neutral to the neutral block then the other sw to a connector block where i would connect my next phase from the next fitting to?
I wasn't saying nothing about his ability,but stuff like this is learnt in the 1st month of college.Its not rocket science matefor gods sake guys give the guy a break.
THEORY is taught in a classroom, NOT confidence.
If you think its a stupid question, don't answer it!!!
well exactly push rod I did not post on here to get abuse I posted because I was unsure. Would it be better not to ask and do it wrong...I think not. What would I learn from that just to ask if i am unsure.
