Currently reading:
Installing sockets in loft, wiring query
Discuss Installing sockets in loft, wiring query in the DIY Electrical Advice area at ElectriciansForums.net
K
KevSex
Hi all,
Just new to the forum so go easy on me :)
I'm going through a personal project to lay floor down in my loft and whilst doing so, installing a couple of sockets to allow for some computer equipment to run.
I've been speaking to a few mates and found that I am ideally wanting to find a ring main to install my socket onto. I feel like I've fell at the first hurdle as this is proving difficult to locate.
I have managed to locate a wire going to my smoke alarm which I'm reluctant to use for obvious reasons.
I've also located a box above my bathroom which I've found is a transformer for a fan in the bathroom. Reading up on this further, the fan is SELV and the box reads "Safety Extra Low Voltage". There is two wires going into this from what I can see however suspect an additional wire coming out from underneath it (connecting up to the bathroom lighting).
I'm looking to find out if the two cables going into this transformer will be part of the ring main and therefore have the right voltage/amperage to support the computer equipment.
Is there any other way of identifying what wire best to use?
I've attached a picture of this too.
Any help would be much appreciated.
Cheers,
Kev
Unless you already have a socket in the loft then you will almost certainly not have any wiring of the socket circuits up there. Everything you have described so far is going to be part of a lighting circuit.
Sockets don't have to be connected to a ring circuit, they can also be on radial circuits. In your situation this decision will be largely based on where there is an existing point on a power circuit to run the cable from.
An electrician will often be able to route a cable from the first floor via a built in cupboard such as an airing cupboard to get to the loft. There is quite often a suitable point in an airing cupboard that could be used to feed loft sockets. It is impossible to determine this without looking at the installation and making an assessment of what can be done. There are a lot of regulations which need to be complied with to ensure that electrical work doesn't present a fire or electric shock hazard.
Hi,
Thanks for your reply. Makes sense to take one up from the 1st floor through a cupboard.
The reason I was thinking one of these wires would have been suitable is that there is a 230V shaver socket in the bathroom below. Would I not be able to take it off that to achieve what I'm after?
Thanks again,
Kev
Not having a dig at the OP, and no disrespect intended, but don't you find Kev's post indicative of the General Public's understanding of all thing electric?
Totally agree with Dave & Andy but will put it in slightly different terms.
If you take power from an existing Lighting cable & start using it to power computers etc, the cable will in all probability overheat and may well catch fire.
The minimum this will do is severely damage your property, which your Insurance won't cover.
A more likely scenario is destruction of the property & possible Death of the occupants at the time and you being prosecuted for Manslaughter.
Call a good Electrician & get it done properly.
I have often thought about this and I think it is in our DNA. We see our parents fiddling with lectric like fitting plugs extending cables with taped joints and it is bourne into us to follow likewise but never gas though because our patents left that alone and we follow suit.
I also note that the OP's location is Scotland. I'm not up to speed on Building Warrants and when and where they are required, but as this is part of a loft conversion, I guess there will be some requirement to comply with Building Regs, which may include the electrical installation.
OP, as you've already been advised, employ an electrician.
How much computer equipment are you wanting to put in your loft?
Appreciate the feedback. Will probably go down the route of getting a qualified electrician to carry this out.
In terms of computer equipment, it's quite a few devices, server, access point, router, raspberry pi, NAS so best to do it right.
Yes mate they apparently do, before work starts. Then a certificate of habitation at the end once inspected.
Even just for putting some flooring down?
From what I was just told, yes. It's not just having some boards put down though, it's having Power & Lighting added.
It's changing from attic storage, to a usable & habitable space.
Will also need any smoke detection extended to cover attic space as well.
Scottish building regs are apparently a lot stricter than England / Wales.
If your putting down some chipboard, to increase storage, I guess not. Putting down some flooring to make a liveable space, I guess it would. Loading, fire escape etc. But BC would advise.
Edit; ^^ what he said.
Yep they are and no stupid Part P :)
My middle daughter has been nagging to move to Scotland, lack of part P would have to count as a big plus :cool::)
Agree with others about getting an electrician in to do the extra sockets, but are you sure putting computer equipment in a loft is a good idea . my loft at the moment is about 55 degrees C , :sweat: so you will probable need some air conditioning units in there as well !
Or some windows :)
Can't say I agree with this, the most it's going to do is trip the breaker due to overload. Can't see how a 15-20A cable on a 6A breaker is going to catch fire (assuming of course a typical domestic lighting circuit)
I think a point was being made @hightower - you wouldn't tap a power circuit with 13amp outlets on a 6 amp circuit so just go with the warning posts - which they are intended judging by the OP attitude.
So you'd advocate someone connecting, sockets to a lighting circuit ?
Don't know how long you've been around this industry, but I've been around it long enough to have seen the aftermath of doing so on more than one occasion. Trust me it's not pretty.
So picture the scenario - you are up in the loft playing with your raspberry pi (still don't know what one of them is!) and the breaker goes due to the overloading that you've placed on the lighting circuit because you took the easiest route and spurred off the lighting circuit in the loft. No strong stairs, you have to manage yourself down the rickety loft ladder WITH NO LIGHTS 'CAUSE THEY'VE TRIPPED and reset your breaker - mmmmmh!
Please show me where I've said such things? My post was merely in disagreement with what you said the outcome would be. A properly designed lighting circuit isn't going to burst in to flames - that's literally the first thing you learn at college. However, I agree with what everyone else has said about a dedicated circuit (or jumping off a more suitable circuit), I just disagree that (untrue) scare-mongering is the way to advise the OP to get a professional in.
It's not scaremongering at all, fact seen it happen. Please don't insult me by trotting out the MCB will stop that happening, that's a crock.
When the op's 6a ? MCB has cleared an overload on multiple occasions then welded it's contacts together, ergo can't clear an overload. What happens then ?.
Anyway as far as I'm concerned, conversation over & done with.
if an attic is insulated properly, i.e. between the roof rafters instead of on the floor, then the heat in summer is vastly reduced, and it doesn't freeze in winter. double bonus.
Reply to Installing sockets in loft, wiring query in the DIY Electrical Advice area at ElectriciansForums.net
