Discuss Installing sockets in loft, wiring query in the DIY Electrical Advice area at ElectriciansForums.net
K
KevSex
Hi all,
Just new to the forum so go easy on me :)
I'm going through a personal project to lay floor down in my loft and whilst doing so, installing a couple of sockets to allow for some computer equipment to run.
I've been speaking to a few mates and found that I am ideally wanting to find a ring main to install my socket onto. I feel like I've fell at the first hurdle as this is proving difficult to locate.
I have managed to locate a wire going to my smoke alarm which I'm reluctant to use for obvious reasons.
I've also located a box above my bathroom which I've found is a transformer for a fan in the bathroom. Reading up on this further, the fan is SELV and the box reads "Safety Extra Low Voltage". There is two wires going into this from what I can see however suspect an additional wire coming out from underneath it (connecting up to the bathroom lighting).
I'm looking to find out if the two cables going into this transformer will be part of the ring main and therefore have the right voltage/amperage to support the computer equipment.
Is there any other way of identifying what wire best to use?
I've attached a picture of this too.
Any help would be much appreciated.
Cheers,
Kev
Unless you already have a socket in the loft then you will almost certainly not have any wiring of the socket circuits up there. Everything you have described so far is going to be part of a lighting circuit.
Sockets don't have to be connected to a ring circuit, they can also be on radial circuits. In your situation this decision will be largely based on where there is an existing point on a power circuit to run the cable from.
An electrician will often be able to route a cable from the first floor via a built in cupboard such as an airing cupboard to get to the loft. There is quite often a suitable point in an airing cupboard that could be used to feed loft sockets. It is impossible to determine this without looking at the installation and making an assessment of what can be done. There are a lot of regulations which need to be complied with to ensure that electrical work doesn't present a fire or electric shock hazard.
Hi,
Thanks for your reply. Makes sense to take one up from the 1st floor through a cupboard.
The reason I was thinking one of these wires would have been suitable is that there is a 230V shaver socket in the bathroom below. Would I not be able to take it off that to achieve what I'm after?
Thanks again,
Kev
Not having a dig at the OP, and no disrespect intended, but don't you find Kev's post indicative of the General Public's understanding of all thing electric?
Totally agree with Dave & Andy but will put it in slightly different terms.
If you take power from an existing Lighting cable & start using it to power computers etc, the cable will in all probability overheat and may well catch fire.
The minimum this will do is severely damage your property, which your Insurance won't cover.
A more likely scenario is destruction of the property & possible Death of the occupants at the time and you being prosecuted for Manslaughter.
Call a good Electrician & get it done properly.
I have often thought about this and I think it is in our DNA. We see our parents fiddling with lectric like fitting plugs extending cables with taped joints and it is bourne into us to follow likewise but never gas though because our patents left that alone and we follow suit.
I also note that the OP's location is Scotland. I'm not up to speed on Building Warrants and when and where they are required, but as this is part of a loft conversion, I guess there will be some requirement to comply with Building Regs, which may include the electrical installation.
OP, as you've already been advised, employ an electrician.
How much computer equipment are you wanting to put in your loft?
Appreciate the feedback. Will probably go down the route of getting a qualified electrician to carry this out.
In terms of computer equipment, it's quite a few devices, server, access point, router, raspberry pi, NAS so best to do it right.
Yes mate they apparently do, before work starts. Then a certificate of habitation at the end once inspected.
Even just for putting some flooring down?
From what I was just told, yes. It's not just having some boards put down though, it's having Power & Lighting added.
It's changing from attic storage, to a usable & habitable space.
Will also need any smoke detection extended to cover attic space as well.
Scottish building regs are apparently a lot stricter than England / Wales.
If your putting down some chipboard, to increase storage, I guess not. Putting down some flooring to make a liveable space, I guess it would. Loading, fire escape etc. But BC would advise.
Edit; ^^ what he said.
Yep they are and no stupid Part P :)
My middle daughter has been nagging to move to Scotland, lack of part P would have to count as a big plus :cool::)
Agree with others about getting an electrician in to do the extra sockets, but are you sure putting computer equipment in a loft is a good idea . my loft at the moment is about 55 degrees C , :sweat: so you will probable need some air conditioning units in there as well !
Or some windows :)
Can't say I agree with this, the most it's going to do is trip the breaker due to overload. Can't see how a 15-20A cable on a 6A breaker is going to catch fire (assuming of course a typical domestic lighting circuit)
I think a point was being made @hightower - you wouldn't tap a power circuit with 13amp outlets on a 6 amp circuit so just go with the warning posts - which they are intended judging by the OP attitude.
So you'd advocate someone connecting, sockets to a lighting circuit ?
Don't know how long you've been around this industry, but I've been around it long enough to have seen the aftermath of doing so on more than one occasion. Trust me it's not pretty.
So picture the scenario - you are up in the loft playing with your raspberry pi (still don't know what one of them is!) and the breaker goes due to the overloading that you've placed on the lighting circuit because you took the easiest route and spurred off the lighting circuit in the loft. No strong stairs, you have to manage yourself down the rickety loft ladder WITH NO LIGHTS 'CAUSE THEY'VE TRIPPED and reset your breaker - mmmmmh!
Please show me where I've said such things? My post was merely in disagreement with what you said the outcome would be. A properly designed lighting circuit isn't going to burst in to flames - that's literally the first thing you learn at college. However, I agree with what everyone else has said about a dedicated circuit (or jumping off a more suitable circuit), I just disagree that (untrue) scare-mongering is the way to advise the OP to get a professional in.
It's not scaremongering at all, fact seen it happen. Please don't insult me by trotting out the MCB will stop that happening, that's a crock.
When the op's 6a ? MCB has cleared an overload on multiple occasions then welded it's contacts together, ergo can't clear an overload. What happens then ?.
Anyway as far as I'm concerned, conversation over & done with.
if an attic is insulated properly, i.e. between the roof rafters instead of on the floor, then the heat in summer is vastly reduced, and it doesn't freeze in winter. double bonus.
I'm a bit dubious about this new fangled insulation between the rafters .... just think about all the cold air venting the roof space..
Our extension was insulated between the rafters... and open to the existing lost which has the old itchy stuff ..... so I added the itchy stuff in the extension...... and I know the new part does get blxxdy hot in the summer too!
What happens if the MCB fails on a circuit that can easily be overloaded by design, such as a socket circuit? So do we need to start lashing in 16mm twin and earth just in case?
Have some trouble getting 2 16mm2 in a socket HT (JOKE)
One might have to consider installing cables with a higher ccc, such as the picture the OP first posted, reg 523.9.
Appendix 15 gives informative guidance on cable size selection for ring final & radial circuits.
Reg 433.1.204 states 'accessories to BS 1363 may be supplied through a ring circuit......The circuit should be wired .........with a minimum csa of 2.5mm (except MI)'. Can't find a similar reg for radials, but guess there must be.
Seen cheeky single sockets, blagged of the first floor lighting, to power the aerial booster, but somebody could plug in a 3kw, for their 'hydroponics' :)
So when would that 6a mcb trip, and what current would flow through the de-rated cable?
An overload is an overload, doesn't matter if it's because too many lights on the circuit, or because a 13A socket outlet is installed off it. If a 1.5mm cable feeding a light can deal with an overload while the 6A breaker begins to work, why wouldn't a 1.5mm cable feeding a socket outlet work the same way? I'm struggling to get my head around people's arguments on here.
But this circuit will not be a properly designed circuit once a DIYer has added sockets too it. And there's a pretty high chance that once they've tripped the mcb a couple of times they will solve the problem with a higher rated mcb.
Yes the 6A mcb will operate the same regardless of what caused the overload.
But the common way a DIYer solves the problem of an mcb tripping through overload is to replace it with a higher rated one.
You also need to think about the size of the overload, the regulations require that we avoid the possibility of long duration small overloads as mcbs can't detect small overloads.
If the result of this additional socket is a load of 7A then it will take a long time to trip, but in all that time the thermal element in the mcb will be sitting there slowly cooking itself.
I think, and experience suggests, that small overloads damage mcbs more often than cables. Normally this results in an over-sensitive mcb but every once in a while it results in an mcb failing closed.
Of course, I haven't got a outdoor socket for my deck lights, switched from inside on my downstairs lighting circuit :oops:
559 Luminaires & Lighting Installations. Reg 559.5.1 connection to the fixed wiring. At each fixed lighting point one of the following shall be used for the termination of the wiring system;
(i) A ceiling rose to BS 67 etc, etc, etc
(v) A suitable socket outlet to BS1363-2
(vii) A connection unit to BS 1363-4
Well experience is something I can't argue against at this early stage in my career. And thanks for taking the time to explain it like that.
A perfectly legal alternative would be to buy an extension lead with six sockets on the end and run the cable through the ceiling to a 13 amp socket. My computer, printer and a couple of chargers are plugged into an extension simply because I don't have enough sockets for them all.
Having an electrician wire up a spur would obviously be better but it's not essential.
Reply to Installing sockets in loft, wiring query in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Novice here wondering what I might be missing. Thanks for any help. I am swapping out an old switch in the bathroom to a dimmer switch. When I...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
