Discuss Is it good practice MCB then RCD ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
preppar
Hello, would appreciate your advice.
Old Federal Electrics D/B, Rederal Eletrics went under, meaning no suitable RCBO's,
Would it be acceptable to use MCB's that are there and install an RCD after MCB ?
Many thanks for your time !
usually OK. think of an old CU where you need to add a RCD for some new sockets.
I'd suggest advising the customer of the significant advantages of upgrading the board. Federal MCBs aren't exactly the most reliable for actually operating under fault conditions.
Reply to Is it good practice MCB then RCD ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Hi all. Looking to refresh the MCB and RCCB (100A 30mA) units to my 20 year old Contactum P12/100N CU installed in my house. I have presently a...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Morning guys, I would like some advice, currently at my workplace, I am replacing a DB and existing wiring in a warehouse. One of the ways feeds...
