Currently reading:
Isolation Switches for New Consumer Unit
Discuss Isolation Switches for New Consumer Unit in the The Welcome Forum area at ElectriciansForums.net
The DNO here (NIE) tried telling a customer that the Electrician fits the isolator and not them. They didn't explain how this could be done with their supply being energised, of course...
NIE utterly clueless in my experiences, guys who fit meters havnt got 2 brain cells to rub together had many encounters with them
I think its common practise on new builds now, but that doesn't help on existing installs. Was a bit of an oversight from eons ( :) ) ago.
They fit a DP isolator only not a switch fuse.
That’s our job and the position the architects like positioning the consumer unit nowadays it’s a struggle to get the builder to fit a 2nd meter box to house the switch fuse.
New connections we always fit an isolator and an earthing block (one of those welded ones).
Personally, I always ask the customer if they’re likely to do some electrical work at some future point and offer to fit one.
If the fuse board and/or tails look old and knackered I fit one anyway.
Quite often the cutouts aren’t sealed and I’m assuming a fair few get pulled so work can be carried out. A few days ago on one job the new meter tails were already in the existing meter after a rewire/new fuse board install, so I’m assuming the electrician did this as well as pull the fuse. It’s fairly common.
Btw, I used to pop into this forum a while back, I’m here (yet) again and have kept the same username. I’ve ended up in probably the most contentious and least respected work by you guys, but heh-hoh, we all gotta earn a crust.
You can throw things at the screen now...
if anyone is wary of pullinf a (dodgy) DNO fuse, cut the meter seal and (with no load on) whip the outgoing tails from the meter. reverse procedure for re-energising. then reseal meter.
To be honest, i dont really think about it, I just cut the seal and pull the fuse.
You can sometimes seal/bodge it back up with a red through crimp if you have enough slack, just cut the insulation of once crimped, whos really going to notice though.
Honestly though the meter guys ive met, couldnt give a monkey's. If I were put in the possition where I feared prosecution then id just go on ebay and buy a load of flag crimps with a tool, cheaper to do it that way then waste my time and rack up my phone bill.
You have to ask yourself why these new snazzy "smart meters" don't have an isolator built in...
If you look back at past copies of P.E. mag all the schemes etc were pushing for it to be part of the meter or a separate one fitted as part of meter change but they would not have it.
As far back as 20 years ago, all the new builds that I have seen have been self-connect meters or a stand-alone isolator for connection of tails.
Reply to Isolation Switches for New Consumer Unit in the The Welcome Forum area at ElectriciansForums.net
