Search the forum,
Discuss Isolator overheating in the UK Electrical Forum area at ElectriciansForums.net
edit
did it not cross your mind that i didnt reply to your post for 16 hrs because i wasnt logged on and probably in bed ?
anyway , i can see getting the last word in is of great importance to you.
congrats.
ok ok , i can see getting the last word in is of great importance to you.
congrats.
16 hours in bed ! Let me guess what you do for a living
...............................You must be a bed tester.
Now you have got the last word in so I have to reply again.
What is the standard or expected PSI/bar on the overall cold water system in the UK??
I remember my pressurised system in Cyprus, is set at about 3 bar (I Think) which relates to around 45 PSI...
Eng54
i believe 2 bar is generally what is expected in a property. Thats what the wet pants reduced the house with 6 bar to.....
i'll happily check out your shower, what time is my flight? Can I go on a plane with the upstairs bit, piano and bar?
Do what I do make a western union splice get a bit of 1.5mm offcut,strip it back with your dykes then wrapped one strand around the cable,pump abit of no lox onto the cable,insert tighten down problem solved.
Reply to Isolator overheating in the UK Electrical Forum area at ElectriciansForums.net
