Currently reading:
Lighting tripping rcd
Discuss Lighting tripping rcd in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Having just read this thread - what testing would have put the OP on the right track more quickly?
Would continuity test at each lighting point between L and N, and then Insulation resistance tests between lighting N and all the other circuit neutrals have worked in showing the problem?
[Just trying to be prepared for when it happens to me :D]
isolate power ,turn off mcbs
disconnect circuit causing problem(L and N)
switch on borrowed load
check between circuit causing problem(L :edit) to other neutrals(one by one)
until you get your reading
that should trace it-might be easier ways
check between circuit causing problem(L or N) to other neutrals(one by one)
You wouldn't do continuity tests first? On a completely unknown circuit wouldn't that be the thing that would tell you about the state of all the conductors and eventually that there was a problem with the neutral :confused:
and not sure what you mean by "switch on borrowed load" (and how do you know which to turn on)
Am i right in thinking that the problem was a live from a lighting circuit to a light fitting and then returning to the CU via another circuit (socket ring?)
Eco-tech - did this fault just show after a CU change or...
had someone been doing a bit of DIY bodging?
just intrigued as to what had happened previously - cheers
take this problem here where you know which pendant is borrowing -we said more or less the same thing
-first disconnect circuit
-bulb out, check between the pendant neutral(with a wander lead) and other circuit neutrals
- bulb in place and switched on you can check between the circuit phase at the board and other circuit neutrals
thats what i'm thinking,never had this problem
Cheers - Reckon i'll just hope my probs are more straight forward - Last time out it took me ages to discover that owner had put a curtain rail screw thru a cable supplying his outside lights which he hadn't used for 6 months. Should have been an easy one but not helped by faults on the garden lights as well - mistakenly thought that the problem was just outside:eek:
Reply to Lighting tripping rcd in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
