Discuss Most compact consumer unit.... in the UK Electrical Forum area at ElectriciansForums.net
I reckon if it needs to be as compact as possible then knowing exactly how many ways needed would be a bonus too.
Good point Andy,there’s 5 circuits at moment but with a unit that small I like to leave a couple spare if possible just to future proof
I hate it when I bring a board to a job and it ends up that I needed a bigger one because there are so many doubled up circuits to split down. Especially important if you are going to order from SBS as you can't pop down the wholesalers for extra bits.
Which is why I don’t consider SBS as a serious supplier ...
Yeah it's a concern. Enough to stop me using him regularly I must be honest.
The kit is great though and a doddle to install. If I had a few dozen boards to do in one go I would consider getting them all from him and also buying a stock of devices to cover unseen eventualities.
Reply to Most compact consumer unit.... in the UK Electrical Forum area at ElectriciansForums.net
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
Lou submitted a new resource: Worcester Bosch Greenstar CDi Compact Boiler Manual - The user manual for most Worcester Bosch Greenstar CDi...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
